1 - 6 of 6 Posts
W
Min. tire pressure ?
My 2003 V-Strom still has the stock Bridgestone Trailwing 152 tires. The recommended pressure for a maximum load is:
Front. 110/80 R19M/C 59H = 36 psi
Rear. 150/71 R17M/C 69H = 41 psi
I got onto a "large chunky" crushed rock road and scared the hell out of myself. I'm about 180 pounds. What do you recommend for a minimum tire pressure to maximize traction in a situation like this?
Bill Pennington
A
Discussion Starter #2
The service manual page 2.26 shows cold inflation tire PSI as:
..........solo riding.........Dual riding
Front.......36..................36
Rear........36..................41
Therefore you could savely go down to 36 if your riding solo.
B
I routinely run 20-22lbs front and rear when doing long stretches of gravel. On my previous BMW GS, they specifically recommended pressures as low as 16lbs for off road. I assume by they meant slow going.
When doing the Dalton in Alaska and the Old Denaly Highway, I ran the 22 lb set up. Worked great. Didn;t travel much faster than 45-50 and it makes a large difference in stability compared to stock pressures used on the highway.
Of course, I carry a tire inflation device with me and air up before picking up speed on pavement.
Give it a try, you will find it makes off roading much more pleasurable.
Hhhhmmmm! I run 36/36 all the time. Ran across the Denali Highway, no problem. My commute includes 7 miles of gravel road each way. You get used to the way the bike squirms, and it becomes second nature. Sometimes the bike feels like it is rolling across a bunch of marbles that someone spilled on the road, but if you just ride through it, its no big deal.
Another idea is to lose the death grip. Many handling problems can be cured by relaxing your grip on the bars. Try it sometime!
W
RDJeff: Thanks for the reminder. Once I got used to steel bridge gratings, (and we have a lot of them here in Seattle), I don't even think about them anymore.
1 - 6 of 6 Posts
