Tire bead breaker from wood scraps!
5808 Views 6 Replies 4 Participants Last post by  honest bob
Tire bead breaker from wood scraps, because I like to build goofy stuff.:biggrinjester:
The stand under the table is actually a front wheel chock I use to hold the bike sometimes. You could use any similar leg material.
· Premium Member
Looks like the kind of thing I'd make. See? It does pay to keep those scraps of 2x4 and plywood!
Only problem is that it occupies a lot of real estate for a seldom-used tool. I can't spare that kind of square footage, but if you can, awesome.
I have a similar setup for a jointer and planer. It folds up against the wall when not in use. It looks like that would be possible with a tire station too.
Shucky darn, for the trouble I go to the local tire guy. I just priced a series of tires and may go with the Anakees because of the price of a set of tires mounted and balanced.
It's just horrible what the tire makers want. $300+ semolians for new rubber. WTF?
Discussion Starter · #6 · (Edited)
Discussion Starter · #7 ·
Good idea greywolf. I actually have done that with a work bench on the opposite wall. It's on door hinges and just falls flat against the wall when not required.
