I find it very irritating and distracting that the throttle grip on my 2014 vstrom 650 moves side up to down on the handle bar about 2 to 3mm and back again. This looseness is very distracting when trying to ride in any sort of terrain as it distracts concentration. Is there a fix ? anyone experience this ?
thanks George
Hi Thanks for that, in my situation its not the rotation that is the problem. The entire throttle slide move side to side about 3mm before hitting stops . So not the rotation but the actually slides too much...
interesting idea ....
thanks George
All the motorcycles I've ridden have a bit of horizontal throttle slop. Have to really to be sure they don't get hung up.
2-3 mm is close to the minimum I would think. How are the throttle cable adjustments? Can you take out some slop there, might help with the overall feel.
Looking thru my 2017 service manual, there doesn't seem to be any method of horizontal adjustment or run-out spec for the throttle grip. Mine has about 2~mm horizontal play as well. The rubber grip rides on an inner sleeve that appears to hold the grip in place by a retaining ring(s) of some sort, which is not visible. The drawings & photos don't show any detail of the parts involved for the grip itself.
Kind of a long way around, but maybe you could go to a Suzuki Dealer and check out the play on a new bike to see if perhaps yours is wearing out. There may be a Technical Service Bulletin (TSB) covering this as well.
Reactions: Spec
Discussion Starter #7 (Edited)
The stem that the handgrip is attached to is about 20 mm in diameter , so if I put a circlip or snap ring on this with a thickness of 2 3 mm then maybe i can get it to stop shimming on very bumpy rods ?
just as a note my 81 Honda cb750f has absolutely no slop in the right hand throttle grip, for me that's nice..
ok I added an eclip, they were on sale ! $3.00 for a set 5/8 inch they had no metric . The green lines point to it in the picture.
This reduced 80% of the slop... another one may be needed ..
