1 - 6 of 6 Posts
Just need a quick refresher guys. What is the procedure for adjusting the slack out of the cables on a Wee. Noticed the throttle had a bit too much slack and made for a less than smooth ride on occassion Thanks in advance for the tutorial.
The adjustors are in the enclosures above the brake master cylinder. Pull them apart to access the jam nuts.
Greywolf
Rrrrriiiight. Maybe I should have gone and looked before asking. I was sort of envisioning getting further into the bike and futsing with hard to reach adjusters. Thanks a bunch Greywolf. Ride On.
From the manual:
1) Loosen throttle returning cable lock nut and screw in adjuster all the way.
2) Loosen throttle pulling cable lock nut and screw in or out until play is 2-4mm (.08-.16 inch). Tighten lock nut.
3) Slowly turn throttle returning cable adjuster outward until you feel resistence. Tighten locking nut.
If the adjusters at the grip are too far out of whack, there are secondary adjusters located in front of the throttle bodies. These, unfortunately, require the removal of a lot of bits and pieces to get at.
1 - 6 of 6 Posts
