I am just curious why Vee and other motorcycles in general have not switched over to a single throttle body and manifold.
I assume this eliminates balancing problems and allows for injectors to be positioned over the intakes.
It would appear to be both cheaper and better
Performance would suffer, especially at high rpm. Harleys have a manifold feeding two cylinders and behave accordingly, making power at low rpm and requiring large displacements. Performance is mostly about air flow and intake manifolds are flow killers.
Super Moderator
I think it could work okay if the engines had even firing cycles. (In a vertical twin with 360 degree cranks) but V-Twins tend to have uneven firing cycles. (What would the crank offset be for an even firing 90 degree V-Twin? Would it be really poorly balanced?)
$Whatever$
Honda NC700x.... What Greywolf said........................
My son's CB250 has a single carb and a manifold. Easy as pie to tune, gutless as all shyte to ride at speed, still vibrates like any other parallel twin. The tuning simplicity is great for a new rider learning how to maintain their own machine but as mentioned the top end performance suffers.
I like the uneven firing order argument
There are MANY cars making good HP with single throttle body. There may not be room for an adequate sized manifold though
Again, the cars are running large displacement, low revving engines compared to motorcycles. Harleys have uneven firing pulses but run off an intake manifold. I don't think any bike runs an exhaust manifold. Manifolds rob power by limiting air flow, the higher the rpms the greater the limitation. Multiple throttle bodies are touted as a hot setup for high performance cars. What is the Advantage of Multiple Throttle bodies? is a short thread on a BMW car site.
Oddly enough, until recient years most single pin V45-52* engines used a dual fire ignition (single firing pulse simultaneously to both cylinders). Since the Pistons were in different strokes, this resulted in "wasted spark" for one cylinder.
