1 - 20 of 24 Posts
I finally got around to taking the fuel tank off my Wee for the first time today to replace the OEM air filter with a K&N. My DL650A was manufactured in January of 2011 and has 10,800 miles on it, better late than never I guess. The only other routine maintenance item that I'm behind on (according to the owner's manual) is a spark plug change, so I'm going to knock that out (along with a routine brake fluid and coolant change) while everything is taken apart. Enjoy the graphic photo, LoL.
272558
Blow from the TB side and not the full force of the blow gun or you might make holes in it.
This filter has a lot of miles left in it. Just tap the bugs out carefully. See if any dust falls out - I doubt it. Re-mount.
I assume that the clean side is clean, means the filter seals well. If so just keep running it.
The clean side looked spotless. Thanks for the help all!
If I went to the hassle to take all the plastic and tank off I would drop a new OEM filter back in the bike and throw the old filter and the K&N in the trash.
Agreed 100%.
If you going to reuse the K&N it would be best to wash and re-oil it as the oil is what catches the finer particulate. A dry gauze filter is about as good as stretching a piece of t-shirt over the air box. A high flow gauze type filter cannot filter as well as a paper or oiled foam filter.
Discussion Starter #14
Agreed 100%.
I'm going to go ahead and clean/reuse the OEM filter.
272744
Had mine apart the other day to solder some wires that were giving me problems and while it was apart, cleaned the filter and added a screen.
Always don't like seeing big bugs/bees in there.
1 - 20 of 24 Posts
