1 - 13 of 13 Posts
Hi all,
on the latest 160-miler round South Devon, the wife complained that the standard Suzi top-box was pushing her too far forward and jutting into her lower back.
Without spending loads of hard-earned, how do I make her more comfortable? (GIVI is an obvious choice but involves some GBP 200+ which I am reluctant to part with...)
I've figured that, provided I forego the ability to quickly unlock and remove it, I can discard the quick-lock attachments and simply bolt the top-box to the standard rack, only some 3 inches further back.
Anyone tried this?
Be safe...
M
adventure motostuff makes a rack that will let you move the box back further to accomodate a passenger.
It works.... just done it myself... tried and tested
Replying to my own post... a sure sign of madness.
Having given it some thought I decided to try my own suggestion. It works beautifully and the wife is now happy again. If you have the same problem, here's the fix:
- Remove top-box from rack.
- Loosen and remove 4 bolts holding rack to frame.
- Remove all top-box fittings from rack (2 front mushrooms and quick-lock rear.)
- Remove all 6 white rubber damping plugs.
- Mark new position of top-box approx 3 inches further back than standard.
- Carefully measure and mark your drilling points on top-box underside.
- Drill 8mm holes at front and 6mm holes at the back
- Reassemble using original bolts through top-box floor, through rack and into frame at front, using original nuts and bolts into quicklock fitting mounting holes at rear.
- Enjoy long miles with less complaining from rear passenger...
Safe Riding
Rory, I don't know how the Suzuki box mounts but my wife had the same complaint as yours. I have a Givi V46 and Givi mount. I made up a couple of simple flat plate brackets that move the mounting plate back 2 inches to give her more room. I'll post a picture when photobucket is finished their maintenance shut-down.
Can you post the link for the exact one you are describing?
Thanks ...Squeegee
I did the same thing. Moved the box back far enough to fit my camping stuff on the seat.
I have a GIVI top bag and while my wife hasnt started yet, I see it in my future.... Looking forward to pics from heavy...
Thank God for pics, they make things for people such as myself actually do somethings on his own. :)
Heavy:
Where those on your bike this weekend? I didn't notice any difference to look at but if they move the case back that much it would be wonderful!
How long were the bars?
Thanks,
Tom
Heavy:
Thanks,
Tom
Yup, they were on. They're pretty much permanent. I can't even remember the overall length. I'll measure them up and let you know. If you want, I can cut you a couple of pieces of steel and you can get them from me.
I did what Heavy did and fabricated my own bracket to move the thing back an inch and a half. I did it slightly different way in that I created two plates that I attached on top of the mount plates. Then attached the plastic rack to the new plates.
That is exactly how I did it. The plastic Givi mount bolts on top of the extensions.
I'd appreciate it! Thanks!
1 - 13 of 13 Posts
