1 - 3 of 3 Posts
HI,
I have recently installed the OEM 12v outlet but find out that my heated grip were connected using 12v plug on the right side. I suppose this plug was for the heated grip but if suzuki are making oem heated grip and 12v outlet, I beleive they put 2 plugs to connect both?
if anybody has the 12v outlet + heated grip installed, please share where you plug both
thanks
I plugged my 12V outlet into the accessory connector beneath the right side fairing. I am going to plug my heated grips into the heated grip connector which is on the left side top of radiator.
HI,
thanks
I'll be adding heated grips before cold weather and already added an accessory plug using the Eastern Beaver kit. I also installed the EB DC8 fuse block and went directly to that for my accessory outlet, leaving the heated grip plug up front available. I purchased the EB wire to plug into that plug up front and power my grips when I get them. I'll be going with the Oxford grips. Check out the Eastern Beaver website. Many items cut to fit the WeeStrom.
1 - 3 of 3 Posts
