1 - 6 of 6 Posts
Whats the best way to get the warning sticker off the tank; its clearly designed not to come off; I've had a go but it looks a mess. Any thoughts.
I used a hair dryer to heat it up, and then picked and picked and picked...
Then I used some WD40 to remove the residue and then a couple coats of wax to blend everything in..
No sign of the sticker now, but it did take a couple hours to get it done.
alcohol is quicker on the residue but the glue stays sticky. wd40 or the like eliminates the stickiness so is good for final cleanup.
apply an alcohol soaked rag to the glue. it will dissolve in a matter of seconds.
1 - 6 of 6 Posts
