1 - 12 of 12 Posts
I did a search and got no specific hits...I can't be the first to want to do this...Any body found a way to light up the hard bags and top case with aux tail lights? Is there a kit that replaces the reflectors with lights?
Thanks in advance...
You can install Hyperlites just about anywhere. They're extremely bright and available with or without flasher modules.
I have been useing AdMore lightings led kit for my E460 that I swap between the FJR and Wee. Two led strips fit inside the reflectors, one on each side. A controller under the seat matches the flash from oem to led. What neat is you get tail lights, turn signals and flasher and brake lights. Very cool. Mike in Fremont, Ca.
Some folks who have had to ride the slab long distances at night have bought 5 LED battery powered bicycle rear lights, and mounting them on the bags. They don't do anything but give you a bigger profile.
It's a lot easier to mount red or black reflective tape on the back of the cases, and possibly more effective.
I added brake lights to my top box and blinkers to my side cases. I used water proof quick disconnect plugs from a giant scale R/C airplane so that I could still easily remove the cases from their mounts. I'll try to take some pics later today and post them up.
1 - 12 of 12 Posts
