1 - 6 of 6 Posts
Im wiring in two 10 watt aux lights purchased from Adventuretech with a small lighted rocker switch. It seems that relays would be necessary.
Is that correct?
Thank you,
John
The rocker switches at the Adventuretech web site are rated for 16 amps, more than enough for the lights by far which draw less than 1 amp each.
Well, there it is; another no-brainer I shouldve investigated for understanding.
Thanks greywolf. Im getting a quality education.
John
Rocker switch blade connections
Need a bit of clarification on the Adventuretech rocker switch- is the copper colored blade hot or to ground (negative in pC8)? I assume the middle blade is to the aux lights.
Thanks.
Check with Rick if you don't get a quick answer.
Youtube vid shows a similar switch with the brass as negative. My dual, weatherproof usb plug has the same color code- brass is negative and silver is positive.
1 - 6 of 6 Posts
