1 - 4 of 4 Posts
hello,
Any one knows how to install these?
If you check the picture, the left looks correct but the right hand one does not align correctly with the mirror and I don't see how I can adjust it.
Thanks.
If you loosen the 2 nuts on the mirror. The whole assembly can rotate to your desired spot Just pull the rubber boots up a little higher to see the second nut
1 - 4 of 4 Posts
