1 - 20 of 30 Posts
Check to see if the suspension links are shorter than the stock 140mm. The stand should not do that. Another possibility is the stand was shortened for a lowered bike.
Brand new stand from Twisted Throttle and brand new bike... :)
And SW Motech doesn't make a shortened center stand for the DL650.
If everything is new, I have no idea how that could happen. Do measure the links anyway.
check your rear preload setting
When on the center stand the rear tire still touches the ground... I don't remember it doing this on my 2006?
Normal? Sure would like about a 1/2 inch more clearance...
it affects the suspension geometry ( I have my preload set to zero so that my duck feet can waddle on the ground)
By clearance I mean tire off the ground when on the center stand... Shock preload does not affect clearance when on the center stand.
Hmmm......
Maybe as a last resort fix, add 1/2" shims under each centerstand "feet". I wouldn't want to have to do that on a new bike + new stand, but I guess it would work?? :confused:
So is your bike sitting higher than stock or something?
Does it lean over more than avg on the side stand?
That's pretty strange.
Not that I can tell - Looks just the same as my buddy's bike... Probably a Monday-morning/Friday afternoon center stand... :)
If you do the triangulation calculation between the stand, front tire and rear tire, just an 1/8" of an inch can make a big difference in rear tire clearance.
I seriously doubt I have a brand-new unique DL650: But that's their position... :(
Discussion Starter #14
Just an update for all...
A borrowed OEM Suzuki stand works fine (at least a 1/4" of clearance).
I am going to have two larger pads welded to the bottom of my SW-Motech stand because compared to another's, mine is is little over 3/16th of an inch shorter fom center of the pin to the bottom of the pads.
Plus - their pads are a little small for my taste.
So somehow mine was jigged up incorrectly.
Mine is short too
I also put a brand new SW motech center stand on my wee and the rear tire also drug the ground. I put the stand on before I lowered the bike with the Kevin Baker links. After the lowering job the rear tire was at the correct height. I assume that SW made the stand with lowered bikes in mind.
Discussion Starter #18
Sounds like you got a Monday morning/Friday afternoon stand too.. ;)
Murphs centerstand
I just put on a morphs center stand, went on easy. Question, what position should I have the side stand in when raising and lowering? Seem like it could become a problem.
1 - 20 of 30 Posts
