1 - 4 of 4 Posts
Hello all,
I recently installed SV racing springs and the gold valve emulator on my front forks. I followed the instructions and when I added the oil I compressed the forks multiple times to get the oil to drain down and then top off. I ran out of oil with one side at 140 and the other at ~142mm but I didn't compress them again after that.
Here's my worry, now when I compress the forks it sounds like the springs are creaking/squeaking and I feel if they were under adequate oil I shouldn't hear that. Has anyone had this issue with new springs?
Also, I tried to follow the Black Magic post of adjusting the suspension and no matter what preload I set I don't get the 25-33% of sag on the front forks. Any ideas on this as well?
Thank you for any help here, the hope is to not pull the front end apart again but I will if I have to.
Have you contacted Blair with SV Racing?
Hello all,
Do you ride to work? If so, ride in on Monday and ping me, I'm in the global. I'll take a look at it.
1 - 4 of 4 Posts
