1 - 20 of 113 Posts
Vendor
:) As many of you already know from the April and May, photo contest giveaways, SV Racing Parts is the Gen Mar Dealer to go to for Stromtroopers and that I offer all Stromtroopers 10% discount, No Taxes regardless of where you live, and $10 Flat Rate Shipping with USPS Priority delivery to your door anywhere in the USA.
International Stromtroopers, email me at [email protected] and I will provide you with the best USPS rate to your door available, It is always realistic,
The Gen Mar handlebar risers are machined from billet aluminum and finished in either brushed aluminum or the black anodized finish.
Shaped like the base of your handlebar mount, they will raise the handlebars upward and back (due to the fork angle), still leaving the motorcycle with a very stock look.
Most riders will have to sit on the bike to notice there is something different. It's more comfortable. Raising the bars up even a mere 3/4" (19mm) makes a real difference in the weight on your hands.
When raising your bars with a spacer design, like our handlebar riser, you raise the bars but still retain the stock angle. This is very important to maintaining even weight distribution across your hands during braking and turning.
The Gen Mar Handlebar Riser is designed to raise your handlebars the maximum your motorcycle will allow. The handlebars will not hit the fairing or the tank when turned full-left or full-right.
There is no need to remove or change any of the controls on the handlebars.
Most installations can be completed in as little as 10
minutes.
The Gen Mar Handle Bar risers are widely recognized by SV Racing Parts, and the overall motorcycle Community, as a terrific system and they do not require re-routing of your cables.
They are made in the USA.
I have the SV Racing Parts, Galfer replacement SS Front Brake Line, required for the DL650 abs in stock, only $49.95, and ready to Shop Free with the SV Racing Parts, Gen Mar Handle Bar Risers,
It is a made in the USA product.
I've tested the Risers on my own DL650 Vstrom, and the DL1000 Vstrom.
They both look and work great.
The One up and One back list at $109.95, Your Stromtrooper price, is only $99.95
The One up Handle Bar Risers list at $79.95 and your Stromtrooper price is only $72.95
These prices are direct from SV Racing Parts. so please email me at [email protected] and I will PayPal invoice you directly itemizing your discounts for you,
Thanks for the support, I appreciate it,
Blair
Thanks Blair
There is no better customer service than Blair of SVRacing. The PowerCommander works great. Good price, quick shipping. What else is there?
:hurray::hurray:
Blair - Do you happen to know if the 1" Gen Mar Riser on an 07 without ABS but with ProTaper Raptor bars will require a longer brake line or control wiring? I am wanting to raise the bars an inch, but don't want to have to re-do all the brake lines and electrical stuff.
Vendor
I believe you are good to go without extended lines on the non-abs models with the the one inch riser,
There is no modification of lines or cables, on the up and back risers on these models,
I have one each of the GenMar one inch risers in Silver and Black in Stock here right now,
If you would like one, email me at [email protected]
Include your contact phone in the email and I will call you right away to discuss it with you,
Blair
Well I am going to ride for a while with the new setup and see if it is bother. Plus I finally sucked it up and bought some happy trail luggage racks to replace my bent Givi racks. If I find that after time it still bothers me, I will get a set from you.
Thanks Blair
SV Racing Parts -- Can't beat that service
If only buying everything was as easy as my purchase of the GenMar up-and-back risers from Blair at SV. Great service, nice product. Thanks.
handle bars
Do you happen to also sell those handle bars? If you do whats the cost?
and if you don't where can i get some?
All the great things you read about Blair and SV Racing Parts are true. Blair called me personally and helped me choose the right Gen Mar risers. For me he recommended 1up+1back. They arrived quickly and were easy to install.
I've only ridden about 100 miles with them, but so far I'm very happy with the more upright riding position. I think this will remove the icepick between my shoulder blades.
Great job Blair! Pleasure doing business with you.
Barbacks
:thumbup: I bought my barbacks a few months ago and they are well made, easy to install, and make my ride more comfortable. Quick shipping and good folds to deal with. Johnny
Vendor
:thumbup: Hi, Thanks for the Kudos, I appreciate it.
The GenMar up and back risers live up to their reputation and patent, They are a great product, and they work just as advertised,
Let me know whenever I can help you out, I will always do my best for you,
Blair
I was very pleased with the service getting these risers but I have to say that the claim of no cable, hose and wire routing mods need done are not the case. I have an 08 1000 and once the up and back risers where on ALL but the wiring bundle that goes to the right grip and the throttle cables had to be
modified.
1. The brake hose bracket at the base of the steering stem needed removed.
2. The wiring bundle that goes to the left grip needed removed from the
metal loop near the top of the steering stem and the bracket under the
steering stem (the throttle cables share this bracket and remained)
3. The clutch hose was rerouted to the back side of the triple tree and the
metal loop at the steering stem removed.
4 To get all the play I could on the throttle cables I rotated the grip towards
the front, it is still marginal when turned hard right.
Without doing all this I was streching everything pretty bad when I turned the bars stop to stop. Maybe if I had pulled the tank I could have found some slack to use but I had it off a week ago to check the air cleaner and I noticed then that EVERY thing was tighter than a ......
If any body can set me striaght I would appreciate it because the last thing I wanted to do was be taking off factory routing assemblies and replaceing them with zip ties. Sitting on the bike the bars feel a lot better in my hands, I wont be able to ride it for a while, this global warming has me all snowed in way up here in the Great White North of southeast PA.
Fixed the problem
I ordered the risers from Blair on Wedensday & recieved them on Friday. Great looking and made product, went on without a snag about a 15 minute job. Took the Wee for a test ride and the up & back risers fixed the problem, no more pain in the back,wrist & shoulders from leaning forward. A product that really works, money well spent and Blair is the best to deal with:thumbup:
modified.
I have the same risers and tried installing on my "09 DL650 . . . NO WAY will they work without extensive cable, wire and front brake line modifications. I am not sure the risers are worth the risk of loosing the correct factory routing of these vital components. I'm still pondering whether to return them or not!
Another happy customer
Still looking for the perfect spot for the handlebars in the risers but here's another happy customer of Blair's. Got the risers and the brake extension for an 09 ABS. Great service and quick replies to any emails.
Thanks Blair
Cat Herder
Received my extended brake line for my 09 ABS. Will get to installing it and my risers when I have a chance.
1 - 20 of 113 Posts
