1 - 20 of 72 Posts
Vendor
:) Hi Everyone, I am happy to announce that the SV Racing Parts, Extended Top Front Brake Line Kit for Riser on the 2012 DL650 abs is now Officially Released and Available for use to all Stromtroopers wanting to run GenMar Up and Back or any other Handle Bar Risers on our 2012 and up DL650 abs bikes,
Once again I have teamed up with Galfer to produce another SV Racing Parts, private part number SS Line Kit that will do exactly what we need it do and meets all the Galfer Lifetime Guaranteed Part criteria,
I promised everyone I would post up when the project was ready to ship, and here it is,
This was a tough one to get around due to the fittings and the way Galfer hard plumbed the brake lines together,
We did it with a Great Looking Black SS 3 Line Kit that ties the whole front end together properly for all aesthetic and safety reasons, and provides the right length Top Line for all the common risers, and without having to incur custom line charge fees for the riser heights,
Stromtrooper members who have already installed the kits from the initial production run have already posted up on the Forum with their Praise for the 2012 DL650 abs Brake Line Kit.
It is a 3 line kit that comes with all the unique fittings you will require and new replacement SS Banjo Bolts and Crush washers for your bike,
It is priced at $114.99 all in with $10 Flat Rate shipping to your door anywhere in the USA,
As with all the 2007 - 2011 DL650 abs models, the one other item I highly recommend that you order at the same time is the CT Single Banjo Bleeder, $19.95, for your Front Brake Master Cylinder,
It will make bleeding and maintaining your 2012 DL650 abs system so much easier. Your brakes and your bike will thank you,
You can find the 2102 DL650 abs Black SS Line Kits on the website SVRacingParts.com Under the category For Stromtroopers, and then Under Brake Products,
If you need and help at all Email me Directly at [email protected] and I will get you looked after right away,
These parts are excellent and will serve you well,
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
You can find the 2012 DL650 abs Black SS Line Kits on the website SVRacingParts.com Under the category For Stromtroopers, and then Under Brake Products,
Blair
Vendor
Blair
Vendor
Discussion Starter #7 (Edited)
Blair
Vendor
Blair
Vendor
Blair
Vendor
Blair
Vendor
Discussion Starter #11 (Edited)
Blair
Vendor
Discussion Starter #12 (Edited)
Blair
Vendor
Discussion Starter #13 (Edited)
Blair
Vendor
Discussion Starter #14 (Edited)
Blair
Vendor
Discussion Starter #15 (Edited)
Blair
Vendor
Discussion Starter #16 (Edited)
Blair
Vendor
Discussion Starter #17 (Edited)
If you need and help at all Email me Directly at [email protected]rts.com and I will get you looked after right away,
Blair
Vendor
Discussion Starter #18 (Edited)
Blair
Vendor
Discussion Starter #19 (Edited)
Blair
Vendor
Discussion Starter #20 (Edited)
Blair
1 - 20 of 72 Posts
