Not sure why YellowHat says it is a pain... sure, you need to remove the body panels to put it on. But once the tank guard is on, it isn't any bother at all, it just stays mounted to the tank. You do have to move the elastic strap from the hinge area if you are taking the tank off, but that's 2 seconds. Heck, you need to pull the body panels off to mount those air horns and HID ballasts anyway! And while a lot of people freak about pulling the panels, it isn't a big job if you always remember to take off the black plastic trim panels that line the radiator area FIRST. A few push pins, a couple screws, a little blue painters tape to prevent scratches to the bodywork, and you can get those things off and on in less than 1/2 hour. Really. I've done it. Without breaking the tabs at the pointy part of the body panels.
I've done several of these bikes and the factory tank guard is pretty nice.
Steve
