1 - 3 of 3 Posts
Owners Manual Special Tools
Has anyone ordered tools for the VS's with the part #'s from the owners
manual.?
The tool I've been interested in is the Mode Selection Switch.
Its a toogle switch on one end and a pin connector on the other.
From what I understand is that it connects to a socket under the seat near
the major electronics of the bike. Once you have it hooked up, it converts
the read out on the bikes gauges to error codes. Most deal with voltage.
There is a possibility of 19 error codes. Examples of some are code: C15
Engine Coolant Temperature. If the voltage is out of a certain range C15
will appear. My shop has talked about checking the TPS (throttle position
sensor) without actaually touching the throttle bodies. This will show C14
if they are not in the correct position.
Has anyone purchased the special sockets.ie. Steering nut wrench socket.
Just curiuos what specialty tools people use for their VS.
Scooter
I made my own from a small toggle switch with a couple of wires and connectors. If you are really cheap, use a paperclip and just short across the connector.
The Vicar
A
But unless you want to purchase an ECU use the switch, but the switch it is 16.00. One of the connectors is a DATA port, yes just like GM, However unless you have aproblem, you will not see any codes, and the TPS adjustment is not performed by using this method. So it is of little use to you.
AATECH
1 - 3 of 3 Posts
