Just bought O.E.M Suzuki Handguards....Take the directions and quickly put in garbage....Totally confusing.... The quality is pretty good but the barend plastic part should be a complete circle and not a notched end...stupit design. Also (IF) you dont want to remove the clutch rubber from the adjuster you can simply pull the O.E.M rubber back over the adjuster and put a small zip ty on it ....just in case you want to take the guards off at some point. ridefast99:biggrinjester:
