Does anyone know if any other bags/panniers will fit the 2014 wee factory side brackets for the adventure model with the large hard cases? Just looking for a smaller bag/pannier size. Looking to buy a bike listed locally that already has the adventure bags on it.
Thanks,
Barender
OEM bags are rebranded SW Motech EVO any compatible with EVO panniers will fit. Second you can also get a Motech mount kit and install it on your choice of bags. Third Motech sells a conversation kit to make frames compatible with Givi.. check twisted throttle good luck.
Do these racks for Wee2 fit on Wee?
Never tried. Very likely as I don't think mount points changed but could be wrong.
BTW Evo Motech are Starbucks POS. Due to combination of toilet paper thin sheet aluminum, lack of metal under plastic corners and flimsy rivet job they will stop being waterproof after 0mph parking lot drop. Motech addressed these issues with Ion which looks almost identical but have welded seams and metal in corners.
If you want ADV worthy cases get these:
https://youtu.be/Vb-eL02LAq0
They use Touratech mounting system and should be compatible with Motech frames good luck.
