Whoops, my bad, didn't notice year.✌
Deleting most of my post, because apparently I misread yours the first time. Nevermind.That same calculator recommends a rear spring of 13.98kg/mm, as opposed to the stock 8.2kg/mm. Most comments on this board would suggest that I need a re-valve at bare minimum to do the rear spring, if I'm too cheap to do a full shock replacement. I know nothing about suspensions, I'll take that advice, but I don't really want the bike out of commission during the riding season while I wait for a part to be shipped both ways and upgraded, and I am too cheap for the full shock replacement. Am I going to cause myself a problem if I stiffen the front shocks and leave the rear as is for the time being?
I stiffened my 2017 with Sonic springs and 10 weight oil. I weigh 190 or so. Didn't touch the shock other than play with preload. I like the handling. Ride is pretty good over most bumps but harsh on square edge potholes.I blew out my right fork seal on my trip to Thunder Bay this week. New seals are on order, I've got a mechanic friend helping me install them. On his advice I looked at replacing the springs at the same time. Race Tech's spring rate calculator recommends springs of 1.1 kg/mm (up from the stock .65kg/mm according to Race Tech's site) for either a novice or intermediate adventure rider of my size on this bike so I've ordered a pair. That same calculator recommends a rear spring of 13.98kg/mm, as opposed to the stock 8.2kg/mm. Most comments on this board would suggest that I need a re-valve at bare minimum to do the rear spring, if I'm too cheap to do a full shock replacement. I know nothing about suspensions, I'll take that advice, but I don't really want the bike out of commission during the riding season while I wait for a part to be shipped both ways and upgraded, and I am too cheap for the full shock replacement. Am I going to cause myself a problem if I stiffen the front shocks and leave the rear as is for the time being?
