What turns off? The engine, the whole bike and electrical system?
The OP reported that the whole bike shuts down, not the engine "The whole bike turn off ". The side stand switch will not turn off the bike, only the engine.Many have reported the bike shutting down when standing on the pegs
They are moving the kick stand with their boot shutting it down
Ensure you are not doing the same thing and insect the stand switch to ensure all is good down there
You can join the 2 stand switch wires as a test of your boot and the switch
The engine just turns off and restarts with the red button, even though the gearbox is in the first or second gearThe OP reported that the whole bike shuts down, not the engine "The whole bike turn off ". The side stand switch will not turn off the bike, only the engine.
Thank you for more information Sami. "This only happens when I ride for a long period".Thank you all, On my last trip, and after I covered a distance of about 120 km, when I reached road intersection point, I had the same previous error, although I made sure that the side stand was tight and that I gripped the clutch will gear was on #1 (the engine turned off and I had to restart it again ). Can’t understand what is the reason yet!? It happened only when I ride for long period
Thank you very much for asking such questions (and my answers are in brackets), thank you, I hope I can diagnose the reasonThank you for more information Sami. "This only happens when I ride for a long period".
Could this mean that the vent in your fuel tank is blocked, causing fuel starvation? Try riding with the fuel cap partially open (but be careful not to spill fuel).
The more information you can give us the better our suggestions.
Do the electrics cut out? (NO)
Do you need to stop for a while before the motor will restart? (NO)
Does it always cut out at a similar length of riding time? (Maybe)
Does it ever cut out at cruising speed - or only when you are slowing for a turn? (Only when I slows down)
Does it cut while on winding or bumpy roads? (NO)
I am sure that we can identify the problem with more detailed information. "The bike stops and I need to restart it" covers a whole lot of scenarios. I realise that you are posting from Saudi Arabia. My Farsi isn't that good.Cheers.
