1 - 20 of 34 Posts
Over four months ago I posted a thread titled "Strom down" (http://www.stromtrooper.com/general-v-strom-discussion/328498-strom-down.html) about a head-on with a semi. After a loooong wait, I finally got the good news that my baby wouldn't be written off, and I got a cheque, so work has started on the resurrection.
Its going to be a naked conversion, and this week, after getting new fork tubes, I finally got it to the point where it is rideable, but still very much a work in progress. The headlight brackets are temporary and I am still working on fibreglassing a new mount for the instrument panel. After that I have to work out how to clean up the tank, and what sort of paint job its going to get, but its just great to be back in the saddle again!
I got the new instrument panel on today, it was a steep learning curve in fibreglassing and a LOT of sanding!
https://photos.google.com/photo/AF1QipPpNqYwqBhahda5fTJjvNA5kppVhHqUrLhpWMsz
So, I tried to upload images I have in Google Photos, but using the image attach icon, nothing happened so I put in the link. Can anyone help with why I can't attach an image from Google Photos?
This is what I get from IE for your link above, likely explains why your inline version didn't work either. It doesn't work in Chrome either for me.
404. That’s an error.
The requested URL was not found on this server. That’s all we know.
I'm using Firefox, and the link goes straight to the photo...I don't understand this interwebby stuff. Thanks fo the quick reply!
Try logging out of Firefox and see if it still works.
So I used Microsoft Edge and got the same error message you did.
I still don't understand how one browser can find a web page and others can't. Its not like Google is hiding on the dark web.:confused:
That looks pretty good. Will be easy to change coolant in future. This wouldn't work for the places I ride, all the bugs would go right into the front of the gas tank and rot. lol
Since your insurance didn't total the bike, didn't they give you money to replace the broken parts? or you just wanted something completely different?
Discussion Starter #13
.Dash is a nice tidy install. Thanks!
Much difference in weight ? Its about 10kg lighter.
Feel much different ?.
It feels quite a lot different, noticeably more nimble around town, I'm more inclined to split lanes etc. Its got a bit more of a "fun" feeling which carries over into the dirt. I find I'll take it to places I'd likely not have gone before, or at least feel less worried going there. Its easier to get up on the pegs and lean forward if needed without the screen in the way, and the niggling worry about scratching an expensive fairing is gone. I guess too that it has lost the 'shiny new toy' feel since the accident so its more of a workhorse.
On the highway I really notice the lack of wind protection, at anything over 80kph I'm leaning forward and wishing the bars were a bit narrower and lower. I'll be looking at fitting some sort of screen down the track.
I got a cheque for the full cost of repairs, about $3500. Fork legs were $1100, headlight and brackets $160, front mudguard $120 and instrument panel say $50 (if you don't count about $1000 in my labour!!), so I've got over $2000 to tidy up the tank and paint it.
I've always liked things that are a bit different, and I enjoy having a project to challenge me. As someone who has always done his own vehicle maintenance, I'd been frustrated by struggling to remove bits of bodywork without breaking little plastic clips, simple maintenance jobs like cleaning the air filter or checking the coolant were a PITA, so I'd always disliked the integrated fairing. Now getting to the air filter involves 3 fasteners, not 20+, and when I open the garage door and see the radiator cap, I get a warm fuzzy feeling!
"Fork legs were $1100"
Was that for just the tubes or the whole assembly including the lower parts too?
I just got the tubes to replace bent ones for $400. now I gotta reassemble them.
Makes perfect sense, I suspected it might but I'd rather not smash it to bits to find out.
This pretty much sums exactly how I feel about a lot of new stuff, plastic clips that break and are crucial to correct fitment.And where the hell do you buy a new one and what the hell is it
called or it's part number ?
Screws that are screwed into plastic and are pretty much a one use item. :furious:
Looks good so far, one of the generic screens should fit up alright.
Discussion Starter #16
You don't have to smash it to bits, I discovered when doing some maintenance a while ago(I had the fairings off) that it would start and run perfectly happily with the instrument panel disconnected, so I took it for a lap around the block without fairings (or front blinkers).
Getting the side panels off the tank and disconnected from the front fairing is a PITA, but once that's done its really easy to get the whole fairing off. You just have to disconnect the three electrical plugs on the left, undo the two bolts that attach the fairing frame to the front of the bike and the whole thing lifts off quite easily. Getting it back on, there's a bit of fiddling to line up the fairing sockets with the brackets on the radiator, but then its easy.
Reactions: Old Time Rider
Discussion Starter #17
I just got the tubes to replace bent ones for $400. not I gotta reassemble them.
The tubes were nearly $1000 Aussie dollars with freight, and my local shop only charged $100 to rebuild the forks. It took me a lot less time to earn the $100 than it would have taken me to do the rebuild!:fineprint:
Discussion Starter #18
Thread resurrection.
Over a year later, the paint is starting to happen, final colour goes on today, weather permitting!
Yes, I'm keeping you in suspense. :)
I like your "look".
I wonder if there is a way to use your new fiberglassing skills to directly apply a "skin" over top of the gas tank.
A small (12"-18") aftermarket windscreen would keep the wind off of your chest (like my old BMW R100).
Discussion Starter #20
I made some brackets that will take the old standard screen and that works OK, but is a bit buffety around the head. I will experiment with the Madstad bracket that I retrieved from the wreck and an aftermarket screen when I find one cheap.
Meanwhile......
1 - 20 of 34 Posts
