1 - 10 of 10 Posts
Hi, I just purchased a new 2012 VStrom Adventure last weekend and have about 100 miles on it. I traded in my Ninja 250 (first bike ever). I've been riding for only 1 year and have little mechanical ability (but am learning). I hear a high pitch squeaking (whistling? chirping?) noise in 3rd and 4th gear at about 3-4000 rpm. Otherwise, I cannot find any flaw, the bike runs great. I'm sure this is far too little information to make any diagnosis. Just wanted to see if perhaps I should expect this or maybe normal for break in period.
Different motor designs have certain characteristics about them. I have entirely different sounds coming from our V-twin than I do from my other twin which is a vertical twin.
There are some electrical noises, like fuel pumps that take getting used to. The air flow around the fairing and windshield can have it's own personality too.
As long as the noise doesn't keep getting louder or more aggravating, just enjoy the ride.
+1
These sound like no other bike out there!
From what I gather, the 12's sound different than all earlier models too.
Crash Bar Vibrations
Check for threads on vibrations from the factory crash bars, there are extensive articles about them.
Try removing them, takes 10-15 mins and ride without them and then reinstall, if the sound disappears install a piece of rubber at the front joint before you bolt them back together.
If it's not that, it maybe your factory luggage, do you have the top box? that also has some buzzing, check for threads on that topic as well.
Good luck and enjoy your new toy.
-and in my case attaching Yann's skidplate to the crashbar drastically reduced those vibes, at 3000 miles I don't even notice it anymore......:hurray:
The slice of inner tube inserted at the connector joint did help with the vibration a bit. You should also check the rear red reflectors . I have seen about half the adventures with the rear red reflectors still mounted to the license plate mount. This causes the rear brace for the luggage rack to press against the cross bar. The amount of noise generated via the luggage magnifies all noises. Creating a very noisy ride. The correct location is the angled bracket at the rear of the mOunting bracket for the metal boxes. THe bracket has a single hole to mount the reflectors. The hard bags have their own red reflectors. When the bags are off the relocated reflectors are in place for increased visibility.
Hmm, I do not have the top box, but I did order one (takes a while to find one that matches the mount). Anyway, thanks for all the responses! I noticed the sound comes at a certain speed (30-40 mph), regardless of clutch engaged/disengaged. Probably the windscreen. Great idea on the skidplate. I read another thread where the bike was damaged on highway because of lack of skidplate. I'll probably purchase it to reduce the vibes (which honestly are non-existant at highway speeds) and protect engine. Thanks again.
Top Box
I usually ride with something in the box, keeps the noise/vibes down. When I commute it's all I use as I like to make use of the gaps between cars. I don't lane split because that's illegal here. !!!
Mine has that same whistling, chirping noise. It's not a vibration. I think it's the wind blowing through something on the bike.
1 - 10 of 10 Posts
