Strange CLICKING Noise?
3135 Views 28 Replies 9 Participants Last post by  Rvator56
2007 DL650. Took it on a short test ride and when I got back I could hear this clicking noise ever so often. It sounds like it’s coming from the rear hub but im not sure. Has anyone experienced this?
Video of Clicking Sound
1 - 20 of 29 Posts
Are you sure it’s not just your hot exhaust cooling? Maybe a heat shield a little loose.
Reactions: 1
It sounds like its coming from the hub or down in that area. I have never heard that loud of a click from a hot exhaust.
Do you hear it when you rotate the rear wheel? Does it change pitch? Is the brake caliper releasing?
The brake caliper drags FOR SURE. The rotor and caliper were crazy hot!
Reactions: 1
check and see if the sliders have ever been greased, good job to be done every season with a brake fluid change.
  • Helpful
Reactions: 2
I think you have a homework assignment. I agree with @twenty to clean and grease the pins with only Sil-glide. It’s the grease to use on caliper pins.
See if this helps.
Changing brake fluid yearly….well I politely disagree with this recommendation UNLESS your bike is stored outdoors.
Reactions: 1
To the wall flowers listening in. It’s a good habit to lay a hand on your calipers from time to time on a long ride or when you get home. Normally they should be warm at best.
  • Helpful
Reactions: 4
See if this helps.
Brake fluid is new in the front and rear. There is an issue with the rear caliper. One of the pads is significantly worn more than the other. I have a caliper rebuild kit for it. I just need to get new pads.
Before you rebuild the caliper, check the pins. They should be cleaned and lubed at all pad changes. The caliper may still need to be addressed further, or it may be fine.
If the caliper piston can be pushed back in to it’s bore with finger pressure, it’s likely fine. If the piston won’t retract without using a C clamp, a rebuild may well be in order.
Good luck.
Check out the rear caliper. I had a potentially BIG problem that made a little noise:
Automotive tire Bicycle part Wood Tread Rim
See less See more
What am I looking at?
What am I looking at @drmonbowen
I see what looks like a messed up brake disc mounting point.
Kind of a weird sound, does it go along with some movement I'm not seeing?
I had a rear brake dragging issue myself, and it was the source of a lot of drama. I greased the contact points around the pads at each change, but the slide pin had worn a groove that caused a hangup which came to a head on a very hot day. In my case it cooked the whole hub, including the bearing and cush drive rubbers, and ruined the disc. I had to force the pads apart with a flat head screwdriver and use only the front brake for the hundreds-of-miles trip home.
I would remove the wheel and inspect the hub area for signs of damage.
Reactions: 1
The noise occurs with the bike just sitting still
Also, the hub wasn’t hot to the touch. This is the first time I’ve ridden the bike. I’ll remove the caliper and rear wheel to check everything out
Reactions: 1
Motorcycle brake pins should not be lubed. They just keep the pads in place. Lubing them attracts dirt and gunk.
Reactions: 1
Isn’t there only 1 pin on the rear caliper? The other end of the pads just sort of rest on something
You might have the rear caliper mis-mounted out of its track. That is one way I have seen a caliper gets installed improperly while changing the rear tire. Another thing I have seen is getting the rear disk into a gap between the back side of a brake pad, and the pistons.
  • Wow
Reactions: 2
there are 2 alignment pins which are shrouded with a rubber bellows. Those 2 pins should be pulled apart, cleaned, and lubed with Syl-Glide.
Reactions: 3
1 - 20 of 29 Posts
