I've been here before about this problem, but I'm still stumped. I know this is the DL1000 section and there's a specific section for GPS stuff, but I really think my problem has something to do with the fact that I'm trying to run this thing on the 1000. Its a Magellan Roadmate 1220. Not the coolest Garmin thing, I know, but something affordable and with enough features for me. I have the propriatory cig lighter power cord and it works just fine in my car. I wired a cig lighter socket directly to the bike battery, not through any switch but right to the battery, including a direct ground to the neg. terminal. There's a 10 A cylinder fuse just in case the leads get tangled somehow, so the wires won't melt off. I fabricated a mount which although hard to describe (and I'm useless posting pictures) esentially provides a secure position with about as much vibration as if it was mounted directly to the fairing "dash". So, although I know vibration can kill these things, I really don't think that's the problem. With the bike not running, ignition off and the unit turned off, it just sit there. That's surely what I'd expect. Funny thing is that even though its connected directly to the battery, when I start the bike, something changes and the unit fires up. It will work pretty good for a half hour or so while I'm riding, then try to shut itself off for no apparent reason. Switching the unit off and on doesn't seem to make any difference and after awhile it just stops working. Magellan has sent me two replacement units and won't send me a third one. I don't blame them. This forum previously suggested many things for me to try, and I tried all of them, but still this situation prevails. So I'm beginning to wonder if the electrical system of the '06 Dl1000 has some quirks that will just prevent me from using this device. Maybe some surge in output that damages the GPS unit? I'd actually consider buying a pricier device if I could be sure I wouldn't have the same problem. Sorry to keep dragging this problem around here, but I figure this is the best place to finally find an answeer.
