I've installed 1.0kg/mm sonic springs in my 04 Vee. But I cannot get my sag set correctly; there's too much sag even with the preload adjusters screwed all the way in. And, my forks use all their travel with even "mild" forest service road riding. (I put zip ties on my forks to measure that.)
I only weigh like 202lbs, so it's not like I'm an overly huge guy; but I do ride as aggressively as possible, as often as possible!
Will longer preload spacers help this? Or do I need even stiffer fork springs?
Also, I have 130mm raising links in the back; which raises the rear 1.125" higher than stock. I'm not sure if that needs to be taken into consideration here?
