1 - 13 of 13 Posts
I ride many miles fd gravel/dirt and sand every week. I assume i should use steel sprockets only or do aluminium sprockets withstand the grinding type friction as well as the steel? There can't be too much weight diffrence in a single sprocket. My rear wheel bearings and axle are ruined so chain/sprocket set is coming up soon. I want to by the best material for my application.
Aluminum wears faster. There are titanium sprockets available, harder than steel.
There are several reports here than steel is better than aluminum.
Aluminum rear sprockets are hard anodized. It's a surface treatment. When it wears through the thin treated area, they go away in a hurry. Racers may use them for a race or three because unsprung weight is important but I wouldn't consider them for other use.
I've never run aluminum on the street, but on SV650 race bikes they last 20-30 hours. And when they start to go away, they go away in a hurry.
If they had a fitment for the V-Strom, I'd go with a Supersprox, a hybrid of steel and aluminum. They list the SV-650 and the DR650, but I don't know if those are different than the Strom.
Edit: I just checked their site and they do list sprockets for the 2004 and 2005 DL650. I don't know if these also fit later years and they just don't list it, or if these two years are unique in the sprocket set-up. It's under Suzuki road bikes, 600cc.
Vendor
Hi Everyone, a number of years ago when we were first all getting Stromtroopers going we initially shipped some Hard Anodized Aluminum out,
I discontinued it because there was such huge variance in the mileage for wear. Some members got 18K and some got as low as 10K,
I know only ship Made in the USA, hardened Steel Front and Rear Sprockets so that everyone gets great mileage and value out of them,
BTW: SV650 and Vstrom Rear Sprockets are not the same or interchangeable,
Let me know whenever I can help you out, If you would like me to give you a quick call and discuss your Chain and Sprocket Combinations just Email me Directly at [email protected] and include your contact phone number, I will be happy to help you out,
Blair
They also have fitment for DL1000s, in various sizes. Just call them and they'll "get you looked after you right away."
Thanks guys! That explains alot! I think ill be gettin me some of them made in the U.S. hardend steel sprockets. I got >5k out of my last set of JT alum and Southwest Powersports 525HSO chain but thats because of a bent axle and shot wheel bearings.:headbang:
Aluminum rear sprockets[snip].
Racers may use them for a race or three because unsprung weight is important[snip].
Yes. And there is even greater benefit from reducing spinning unsprung weight (reduced angular momentum).
Steel is a great material for sprockets. Don't waste your effort with aluminum, no matter the coating.
Discussion Starter #13
I bought Renthal front and rear and a Western Power Sports 525HSO chain. I have had great luck with WPS in the past...Also orderd wheel bearings, sprocket hub bearing and new axle. Now, I can get more then 4500 miles out of a chain/sprocket set. If this doesnt keep the sprocket from wobbling, The only rhing left to rebuild would be the swingarm bearings or bushings.....whatever it has.
1 - 13 of 13 Posts
