Braided stainless steel-reinforced brake hoses only (possibly) effect the braking feel. Keep in mind that the stock brake hoses have fiber reinforcement--they aren't just rubber tubing.
Stage 1 upgrade -- HH rated pads in front, either Galfer or EBC. Retain the stock hoses, flush the brake fluid, bleed out all the air and see how you like the feel.
Stage 2 upgrade -- Blair's adapters with 4-piston calipers and maybe different master cylinder on the newer Wees, different HH pads, stock hoses, flush, bleed,
you'll like the result.
If you aren't satisfied with the feel of the brakes, and they've had the air correctly bled out, now buy the stainless reinforced brake hoses.
If you want more bling, buy the stainless brake hoses with the clear outer cover and buy wavy rotors. (The clear cover is only bling; black EPDM cover offers better long-term sun protection.)
This is how stock brakes hose is made:
BrakeQuip OEM Rubber Brake Hose
