1 - 12 of 12 Posts
Hi All,
I know a couple of your on the ride from Barrie had the Stebel horn.. I am not sure who it was.
I now have a Stebel but would like to see how you installed it. In particular if you have the 650.
(I have done a lot of searching and it looks like the right lower rad bolt makes sense but other suggestions are very welcome.)
I noticed a rubber plug in the left side of the forward cylinder (there's also one on the right). I've got mine there for now. An M10 fine thread bolt will work. I went with this side since I was already on that side with the wires. I pulled the stock horn out and mounted the relay where it used to be. That saved me from extending the stock horn wires. It's only been on a couple weeks, but so far so good. I do need to replace the bracket I used since it is too flimsy (just used something I had on hand).
Hey Tom,
I have a Stebel on my V. Its mounted inside the left fairing panel. Out of sight but certainly not muffled.
I got tired of trying to find one locally and waiting for my local dealer to call me that they had one so I ordered from Twisted Throttle. I ordered the wiring as well.
It all came very quickly and I don't think I got hit for any duties or taxes.
VTom,
Where did you get the horn from...locally?
Hi Heavy,
How did you attach it? That seems to me to be a good logical place but I can't see any simple way to attach it.
Hey Tom,
Hi Heavy,
I got 2 of these clamps to fit on the tubing for the fairing support.
I bolted them to a small steel plate which I had drilled to accept a bolt that fits into the mounting slot on the Stebel.
See below for a diagram to explain.
Top view
Brilliant! So two clamps attached to the tubing.. I see tubing running vertically that is on either side.. is that the right tubing? Sorry to be so dense.
There seems a lot of room in there.. has anyone ever considered putting a small "glove box" in there? In particular on the right side.
1 - 12 of 12 Posts
