Helping my friend out with his 2007 DL1000 charging issue. Some initial confusion which i have narrowed down so looking for any advice.
No charging at all at the battery so figured it was standard issue magnet migration. Pop off the cover. and nope, magnets are perfect. So perfect indeed that we decided not to do pre emptive JB Weld. There's substantial amount of the old glue between magnets and I don't want to a) JB weld over it for fear of it coming loose. and b) start picking off good glue for fear of dislodging something that looks well brand new. So, for now, we'll leave well enough alone. And yes I know the advice you'll all give.
Stator has one burnt leg. Shows 0.2 ohms across all three legs bu the ground test is iffy, the numbers bouncing around faster than faster a meth head bouncing his head off the wall. So burnt wiring and iffy ground sounds like stator issue.
Off with the left side cover and disconnect the stator from the RR. Noticed that wow connector is big and higher quality than i expected. Indeed so big cannot be routed out through the framer. Just too tight for such a big connector. Jesus, do we have to take crap off the bike just to route the wire. And that's when io noticed the stator wires were all yellow and had shrink wrap where there should be one.
Sure enough someone has already put an SH775BA RR on. Complete with upgraded connectors and thicker wiring. Hey the wiring going to the battery is huge. I am 99 per cent sure it's a roadster cycle package. Connectors look the same and there's even the RR mounting bracket Roadster sells.
Problem is that according to the Roadster Cycle site, thee SH775 cannot be tested using a multimeter. needs some sort of bench test to do so. So my questions are:
1) Has anyone who has ever upgraded to an SH775 — or any of the newer versions _ ever burnt one out? In other words, what are chances of failure
2) Is it really impossible to test an SH775 with a multimeter like jack at roadster says or does anyone know a test?
3) What does anyone think of Custom Rewind in Birmingham. I do not trust Ricks or Electrosport but Custom seems to have some positive reviews. It makes not sense to buy a new for CAD $400 and then snip off the connector brand new so unless the the SH775 is toast — which then makes it feasible to revert back to all stock suzuki hardware cause you need both — a rewind seems to make the most sense.
If any one has an opinion about the three questions above appreciated.
David
David
