Was wondering if anyone could help with a problem I'm having (or point me to a thread if it's already addressed elsewhere; I did a search, but didn't find anything).
My battery wasn't charging, and a multimeter test showed no change in voltage whatsoever from revving the engine. So, likely r/r or stator problem. Took it into a shop. They tested the cables from the stator, and found all three leads were grounded out. But when they opened up the stator, it looked pristine -- the mechanic said it looked brand new. The shop's solution is to install a new stator to fix the ground problem, and I've got no problem doing that, so long as that's likely to fix it Anyone know whether there might be another problem we should be looking at?
