Put on new chain and sprokets, no problem. Having trouble with clutch adjustment. Everything seems fine(free play) but when I let out the clutch in 1st gear it stalls. The only way I can ride is to keep the revs up and fan the clutch. Thanks DAN
I've done this in the past, thought I was being careful but not careful enough. All part of the learning curve :yesnod:Did the center of the clutch adjuster come out in the process? You may have put it back wrong. Did you check for 1/4 turn free play on the adjuster?
