The throttle closed position on my '12 isn't a solid, sudden stop, it's a bit squishy for about 1/8 an inch of grip travel. Anyone else notice this?
Did you recently tighten your bar ends? Install barkbusters? Anything that would interfere with the throttle "snapping" shut.
You maybe stopping on the return cable length not on the throttle body stop.
Shorten the "outer cable" on the return side and see if you get a different feel.
Are you familiar with twin cable throttles ? they will feel different to a single cable throttle.
Yes. I retightened the bar end and repositioned the right hand switch assy that holds the mirror, etc. after a bike drop.
Seems like it's hanging up on the way back to "zero" while relying 100% on the throttle spring(s). Loosen up the stuff you messed with and test to see if you get a "solid" stop at zero while in a "free floating" condition. If you do, then tighten things up again while testing the unassisted throttle return at each step. If it starts to hang up, go back a step to figure out why. Address and then proceed until it's all tightened up.
Does sound like some little thing is cock-eyed. Do you have BarkBusters or OEM Bar-End wieghts? Both could put pressure on the throttle grip tube's end resulting in a choppy return to the zero position when relying 100% on spring tension. You want to make sure it works in case you have another "off-seat" experience, so the engine doesn't keep going while in-gear or neutral, as you know.
