Hallo,
I'm new to this forum, and after searching for an answer to something else related to the V-strom. I found this place :thumbup:.
I was fiddling with the clutch cable as I had earlier done something to it that the biting point was more or less on where you let the clutch goes.
I found the answer how to sort that, and if it's not perfect, it better than it was.
When I was finished I tried to test where the new biting point was, and when I revved the engine, at a certain point I heard a nasty load squicking noise.
I turned off the engine, and tried turning the back wheel manually.
The noise was still there, but only when moving the wheel forwards, and stranger still, only when the valve you fill the wheel with air is at it's highest point. Every where else it was quiet.
Anyone knows what this could be?
