1 - 9 of 9 Posts
Tried to search out the answer but my ADD wouldn't let me look very long. I've noticed that when descending on fire roads or gravel, the bike gains way more speed than I want. Thus I'm trailing the brake to slow it down which has led to some motox feeling slides in turns. I'd like to gear it down some with new sprockets but am not really sure of the right combo.
This is a toy not a commuter so I don't care about the effects on gas mileage. Does anyone have a suggestion as to the best F/R sprocket combo to achieve this?
If downshifting isn't enough, drop a tooth on the counter sprocket.
Are your tires suitable for your riding surfaces?
Is the bike really rolling too fast in 2nd or 1st gear? Are you applying some front brake to match the engine braking of the rear wheel?
I run dualsport tires although like most ds tires I suppose they're a little more street biased. Yeah, 1st gear too fast, closes on bike ahead way too fast. 2nd gear is fuggitaboutit!
Sounds good. Any recommendations?
Stock countersprocket is 15 teeth. Try 14. Chain is 525.
I went to 14 tooth counter sprocket and there was virtually no change in my mileage. I really like the ride and I am now using all six gears. Previously, I almost never used sixth gear. I usually ride between 55mph and 60mph, so I don't miss any of that top end speed that some people use.
I ride a lot of forestry roads as well, have tried several combos. A 14-47 does good but I wanted more tractoring effect, so I went with a Vortex 54 rear and used my trade to build a 13 for the front. 1st and 2nd worked out well for decellerating down steep gravel grades while still giving me awesome bottom end power for the real tough stuff.
Vendor
:) Hi, I know what you mean about closing in too quick and wished you could lug along at a slower speed, I was just out and thinking the same thing myself this past weekend.
I've got all the front counter shaft sprockets in stock here if you like,
Email me at [email protected] and I will be happy to help you out,
Blair
1 - 9 of 9 Posts
