1 - 20 of 32 Posts
2014 all stock Vee. Mine also reads 90 when I'm doing 75. Also noticed when I ride 10 miles exact by GPS by bike registers 10.3 miles. I have to get this fixed as it racking up too many miles on my bike too. As this electronic gadget the only way?
Count your sprocket teeth. I can't imagine any way the stock 17/41 combination can be that far off. An electronic fix is the only way to handle the change. Since the Vee2 gets its speed signal from the ABS wheel sensors, it doesn't have a separate speed sensor with a connector you can separate and install a SpeedoHealer or SpeedoDRD into. You'd have to cut the pink/white signal wire and splice into a white/green switched power wire and a black/white ground wire to install such a device. It's been done and works fine. If you correct the speedometer, the odometer will read a little lower than stock, or actual for that matter. The stock odometer is around 2% higher than actual while the stock speedometer is around 8% higher than actual.
http://www.stromtrooper.com/dl1000a-2014-2016/256810-2014-dl-1000-vstrom-u1-speedodrd.html
http://www.stromtrooper.com/dl1000a-2014-2016/275746-speedo-drd-going-2.html
http://www.stromtrooper.com/dl1000a...4-dl1000a-speedometer-correction-success.html
http://www.stromtrooper.com/dl1000a-2014-2016/236394-speed-healer-new-2014-a.html
Thanks for the info, I'll count my teeth for sure. What's odd to me is that if the speedo is based from the ABS sensor it's dependent on the RPM of the wheel only. Changing sprockets and engine RPM should have no effect on the speedo but I can see where changing a rim and/or tire profile would. I still have standard rims and stock tire. Would a smaller sprocket in front cause the speedo to read high or is it the other way around? If anything was changed I would think the guy before me changed to get better acceleration but didn't tell me.
I hadn't thought about that. Changing the sprockets on a Vee2 shouldn't have any effect on the displayed speed if the ABS sensors were used for the speedometer too. Could it be the speed is calculated from the engine rpm and gear chosen? Vee and Glee speeds are taken off the front sprocket shaft while Wee speeds are taken off the front wheel. The pink/white wire on the Vee2 that feeds the speedometer comes off the ECM so the ECM calculates the speed from available inputs. I'm moving these last posts as they've gone off topic for a Vee thread.
I checked my speedo against GPS before and after changing from 17T to 16T front sprocket and there was no change. My speedo is off (higher) 3%.
Thanks. So that would indicate the ABS sensors are used for the speedometer also. How in the world could Steve's Vee2 indicate 90 when doing 75mph? 10.3 miles on the odometer when 10 actual miles have been traveled is within the envelope of typical V-Strom odometers though.
I think it must calculate off the RPM and gear as you mentioned. If we were the engineers you bet we would have it calculated off the wheel RPM only and using the rear tire I guaranty we could get it within 1-2% accurate. In today's day and age it baffles me that manufactures can't get speedo's to read correct on bikes. Cars do it right....
Anyway, I can live with the speedo being off but when the bike shows I have 7000 miles on it and I really only have 5600 that's a problem. Headed out to count my teeth tonight. Now I have to figure out what to remove to see the front sprocket...
10.3 is to 7000 as 10 is to 5600 doesn't compute. Your real mileage at an indicated 7000 miles with that 10 to 10.3 discrepancy would be 6796 miles. I know and trust Bosnjo's reporting and he says there was no change on the instruments when he changed sprockets. I think from your posts Steve that you are miscalculating something.
... In today's day and age it baffles me that manufactures can't get speedo's to read correct on bikes. Cars do it right....
I've wondered for some time .... I love to see a authoritative account about this whole issue. Maybe the forum can get an interview from Suzuki HQ.
I can't tell if my memory is tricking me or if I just plane have it wrong but - I don't recall this issue before the USA Dept of Transportation cracked down on and threatened the Japanese superbike manufacturers. Mrs. Doyle, if I have it right. That was a period when speedometers were limited to 80mph. I'm pretty sure this topic never came up in the days of planning longer trips with printed turn-by-turn directions and the mileage always came out perfectly. While I'm sitting here thinking about it and talking out of my tail light ... The BMWs I ride don't over report the speed. If I were cynical, I'd wonder if there is a motive by the Big 4 CEOs to keep insurance rates down in the market place by reducing the number of speeding tickets. Even shaving the warranty exposure by 3% over the annual fleet adds up. But that is crazy talk. Or it would be if we really thought they really can't get a speedo right.
So here is my compute. At 90 I'm doing 75 which is 20% hence the 20% lower than 7k is 5600. Problem is most of my 10mile commute in the morning is about 55 and it appears the slower I go the more accurate it gets hence the mileage being more accurate. I guess that makes sense because it's most accurate when I'm standing still at a light..... If I drive to my house in the mountains my average speed is about 75 (AKA Suzuki 90) and I'll bet the total distance would be 20% higher. I'll try it the next time I go on the 160mile trek.
I checked the back sprocket last night and it does have a 41 stamped on it. Assume this to be teeth. I'll attempt to find the front before she goes to the dealer.
I don't see any way you can be indicating 90 and have the GPS show 75 on a 2014 or later DL1000A unless you are having a malfunction nobody has ever reported before. Speedo error will be a percentage error so the difference in true v. indicated will increase as speeds increase.
I think I have a malfunction nobody has ever posted before. Even when I ride with my friends with intercoms on I'm like "slow down guys you are doing 95" and they are laughing saying they are doing less than 80.
The speedometer is in the neighborhood of 8% fast across the entire product line. An actual 75mph indicating 90mph is a 20% error though which is unheard of. Changing the number of sprocket teeth from stock on a Vee or Glee (see my sig) will change the reading. I don't know about the 2017 650. It will not change the reading on other models.
I think there is a problem with your bike. Just as Greywolf said, on higher speeds the difference will increase but 20% is something I've never heard about, bike or car...
I don't know much about speedo healers but that may be something to go with if there was adjustment on them so you can compensate such a high percentage of difference.
I had a 2004 DL1000 before I bought my 2014 DL1000a and they both had the same problem. Most motorcycles are over clocked for some reason.
To answer the questions about the sprocket teeth: No, changing the sprocket teeth will not change the indicated speed. The reason is that the speed counter is taken from a spoked flange on the front and rear wheels. The reason that they are on both wheels is that the ABS and traction control use these signals to tell if the front and rear wheels are moving at different speeds. The only way to change the indicated speed is to intercept the speed signal after it leaves the ABS and before it gets to the instrument cluster speedometer. The posts referenced by Greywolf all address this issue and suggest different places to intercept the speed signal (a pink/white wire).
I measured my speedo at +8% and my odometer at +4%. After correcting it my speedo is spot on but my odometer is now -4%. A bit of a bother but I can live with that.
Cheers!
My 2014 has been showing 6 mph faster since new. I just figure this is how they meet EPA mpg requirements. Surely my bike would get 40 mpg's if I am going 64 mph instead of 70. Now that I compensate for the error I get 37 mpg.
Never thought about the EPA rating, but you have a good point. Because the Indicated speed and the odometer were bother over clocked but at a different amount (speedometer = +8%, odometer = +4%) when I corrected the speedometer the odometer registers low now (-4%) the result is that not only does it seem like I'm putting fewer miles on the bike, but the indicated milage is lower (34.5 MpG now vs. 40.1 MpG prior). That's way more than 8% difference but since my driving habits haven't changed and nothing else on the bike changed except the speed correction it's gotta be that.
If I work out the math when I fill up even with the indicated odometer miles, I'm actually getting closer to 38 MpG and track with a GPS and then work it out with a true distance the actual milage is closer to 40 MpG which is what was indicated in the first place. I'm not sure what algorithm Suzuki is using to work out the mileage but whatever it is, correcting the speed seems to mess it up.
Cheers
Try somebody else's GPS.
To get the most accurate GPS reading you need a long, straight, absolutely steady speed run. Curves, speed changes, buildings, bridges, trees all put inaccuracies into the speed signal.
1 - 20 of 32 Posts
