What's not clear to me after two cups of weapons grade French Roast, is what year and model you have. Reading the tea leaves 😉 I gather this is a DL 650. Sincnce 2011, I believe, all V-Stroms came with ABS standard and the speedometer was linked to the front wheel ABS sensor digitally, so changing sprockets will only change engine rpm at a given speed. Older bikes (2004-'09) were mechanically driven and sprocket change will have an effect.
But if you're happy with the performance of the bike, a speedometer correction device would greatly improve the accuracy and costs about the same or less than a set of sprockets. Adventure Tech sells one that will fit any V-Strom, and Owner @richlandrick is an advertiser and member here, and can answer any questions on any of his products.
Excellent service before and after the sale.
