15 | 09482-00635 | PLUG,SPARK (LMAR8BI-9) | $26.99 | $25.10 | 4 In-Stock |
I ride most days, but it's always garage kept. I even park in a garage at work.Its possible that the rusty one was poorly plated. I can't see water staying in that area for long when the motor is heated up unless the bike was left lying up in the open for long periods in the wet.
Partzilla only had three in stock. Revzilla had them all in stock and a bit cheaper than Partzilla.Have a hard time getting those LMA spark plugs? Did you replace them with LMA's? Or something else?
DANG!
15 09482-00635 PLUG,SPARK (LMAR8BI-9) $26.99 $25.10 4 In-Stock
The browned one. Yep.I have seen plugs rust like that when they were no tight enough and the exhaust gasses cooked them.
There are counterfeit plugs being sold too.
If it is counterfeit than Suzuki installed a counterfeit as that was the original spark plug. It felt properly tight when I removed it. The rust is almost certainty due to the location of that plug. It is the only plug with the nut exposed to road gunk. The boot on the lower plug does not cover the nut like it does on the upper plug.I have seen plugs rust like that when they were no tight enough and the exhaust gasses cooked them.
For my comment Andrewhartzell, I was looking at the threads of the top one. The crusty exterior is clearly a result of its outside environment. Can't be helped. Lots of compressed air before the plug is extracted.If it is counterfeit than Suzuki installed a counterfeit as that was the original spark plug. It felt properly tight when I removed it. The rust is almost certainty due to the location of that plug. It is the only plug with the nut exposed to road gunk. The boot on the lower plug does not cover the nut like it does on the upper plug.
Thank you or the clarification. it is possible that I didn't tighten the top (in the photo) plug properly after inspecting it at 15,000. In fact, I torqued them to 9.5 nm instead of the 11 nm spec for fear of them stripping early.For my comment Andrewhartzell, I was looking at the threads of the top one. The crusty exterior is clearly a result of its outside environment. Can't be helped. Lots of compressed air before the plug is extracted.
There was a mention of counterfeit NGK plugs on a different thread that I was a part of. The shi**y part of those things is on the inside. Amazon seems to be a part of those getting to market. Your irridium tips look perfect in the photos.
