1 - 3 of 3 Posts
Well a shake down ride today to dial in the new Elka shock and I'm pretty happy how things are going atm, at least until I can sort the front :wall:.
I'm not sure on whether I need to play with the rebound IE heavier oil or the compression (RTGV spring preload).
Bike doesn't bottom hard on big hits, but does use all of the travel (ziptie on fork tube).
my issue is with the smaller stuff (both on and offroad), although it seems to jarr, after I increased the preload it felt firmer but better if that makes sense ?
after hitting an obstacle (tar patches or part exposed rocks) the initial impact doesn't feel to bad, but afterwards feels flat ?
as if the wheel is impacting not rolling over ?
current Set up
(I'm 90ish kg out the shower)
fork brace
0.90 sonics
10wt motorex @ 135mm
6 8mm comp holes
rebound hole as std
yellow spring with 2 turn preload
std top plate
any ideas
muddy i'm 85kilo and ive got .95 sonics and 110mm from the top , 7.5 weight with fork brace and steering damper. fork tubes raised 25mm thru the trees and just put on raising/lowering links and dropped it 20mm in the rear...but now it shows up the short fall with a standard shock,,,,its on the wish list i'm watching yr story on the new shock..but front end sweet now
Discussion Starter · #3 ·
thanx for the feedback Greg, are you using RTGV's ?
which oil are you using ?
the Elka was a huge improvement straight up, I raised the rear 10mm at the shock base and dropped the front 4mm. corners like its on rails and no sign (yet) of headshake off road
1 - 3 of 3 Posts
