Same thing with mine.My Stebel is mounted properly and within their specs....however if the outside air temp is below 55 or so degrees it only produces a single note.
When the outside air temp warms up a bit it then makes a dual note....
Weird but true.
Same here.Same thing with mine.
Stebel Nautilus Horns SUCK - ADVriderHaven't had any issues with the Stebel from PWD. One thing to note, I didn't put on the intake tube, and I do hit the horn once or twice every ride (have NO idea why, but heard it's good to do for the longevity of the horn).
Didn't say they were different. Simply said I haven't had any issues with mine, and it happened to come from PWD (who also makes a great mount for it).Stebel Nautilus Horns SUCK - ADVrider
I don't see why PWB's Stebels would be any different from these.
Can you post photos of how you mounted the Fiamms?Mine died in short order, pretty much the same way. You could blow compressed air through it and it would work, but not on its own. I have no need for an unreliable horn so I run Fiamms now. They have held up to the weather/dirt for a hundred thousand or so kilometres of year round riding. Easier to mount, too.
I haven't got any photos, but it's simple enough to describe.Larolco,
I too would like to see your Fiamms horn setup. Mounting and wiring if possible. Thanks.:yesnod:
