21 - 40 of 46 Posts
Hey Big B, What is the REASON you say they suck? Had one fail on you?
Here is your quote...
"Fram SUCKS...there I said it, and ya'll aint changing my mind. When a majority of people say that something sucks, it usually does. To those of you that use them, have good luck, and actually like them....I am tickled to death for ya."
Majority of people say they suck? Can't say that I see enough negative on this forum to even get close to a "majority".
I ran a 1983 T-Bird Turbo coupe to 230,000 miles with the original turbo on Fram oil and air filters and the only reason I don't have the car is a lady in a Buick with a Purolator oil filter rear-ended me and totalled the car.
Yes, you are right... Be tickled for those that are satisfied with them... I'd say that's the majority.
Have a good one...
I've used Fram oil filters on the Wee, all three of my previous bikes, and on my truck. Never any problems. I've used regular motor oil in all my bikes as well. No issues ever.
I am fairly religious about changing my oil on all my vehicles, so that is probably the reason.
I'm wondering about the tightening comments...:confused: People really follow the directions on the exact amount of turns??? Wow.
Tighten the damn thing till you can't anymore and then check it after every ride to see if it's leaking. Tighten and add oil as necessary.
My humble opinion.
Kinda late on this with my input after all the shooting is done. I bought two Suzuki filters when I bought my '07. Followed the change soon approach to break-in. Read the "two turns" bit and struggled to get the two turns after contact. But..... That is what was "factory recommended." Started the motor and all was well. Ddecided that I needed to take a spin to confirm all was well on the oil change. Out of the drive and down the hill , down shift for the stop sign and the rear end slides???? I look back to see a skid mark and see a trail of oil!!!!! Oil was pouring out of the bike. I was fifty yards away from my house. I coasted back. The autopsy revealed the seal had torn loose. From overtightening is my guess. I have never tightened a filter more than hand tight before. Won't do it again. The price of the Suzuki filter at $9.99 is WAAAAY more than the FRAM from Walmart. Price is an issue when the FRAM is $4.95. Just my late piling on. Brian
From http://motorcycleinfo.calsci.com/Filters.html:
"Oil Filters come basically in three qualities. Very good, with excellent filtration; normal; and really incredibly bad. This last category, really incredibly bad, should obviously be avoided. Accordingly, never use a Fram, Pennzoil, Penske, Castrol, or Quaker State oil filter in any motor you like. All of these filters are made by Fram. The filter element itself is a normal paper element, and probably no better or worse than anyone else's paper element. However, the end caps on the filter element are made of cardboard in these filters. There are numerous stories of these cardboard end caps getting saturated with oil and coming apart, putting little cardboard fragments directly into the oil flow into your engine bearings."
Filters and such
Been doing my own maintenance and repaires for 30 some odd years and almost always go with the OEM filter on my bikes and cars and truck. I drive Toyotas for their build quality and reliability plus I have close friends with a Toyota dealership who also ride motorcycles. Anyhow, I use an OEM filter tool for both cars and bikes and tighten to factory spec. NEVER had a problem in all those years with any oil filter. I'm also a licenced mechanic, which doesn't mean anything one way or the other, but sometimes when you do something for a living you get good at it, sometimes things just turn to crap in your hands. Use the best tool and product for the job regardless if the price is low or high and apply the right amount of care and attention.
Have a good one...
Because of this very exact article...and the fact that "motorcycles" engines differ greatly than car engines do. Use what you like, but FRAM still sucks. And since they make filters for other manufacturers, they must suck too.;) I am not going to try and save myself 4 or 5 dollars for a cheaper filter, when I can get a better made unit for a little more.
As for the mentioning of the OEM filter being overtightend causing a major leak.....I am really surprised. I can easily do the 2 full turns on the OEM, and it doesn't take much effort. I use the Suzuki oil filter end cap wrench, and it goes right on without a hitch. I would much rather go with a little cheaper brand of oil, than to use a junk Fram filter. Plenty of other good alternatives if you want to avoid the OEM cost. I am not bashing other manufacturers "just Fram" and the FRAM duplicates.
Brian
Nope. Wish there were, though . . . my cruiser and truck luv'em.
Yeah, I was looking yesterday for one... dissappointed to find there wasn't one listed.
Good info and exchange of posts!
I run a Suzuki filter currently, so know my "antagonism" comes from wanting to see why opinions are formed. Usually a little jabbing gets folks to open up, like in this case. :p
With that said, I am real curious about the cardboard end caps coming apart inside the filter and getting in the main bearings. Was that documented, or assumed?
In any case, I'd bet a buck that the Fram filter in question had high mileage oil in it, and it sat over the winter, deteriorating in the sludge forming crap that old motor oil becomes. When that poor beast was fired up in the spring, the pressure inside from neglect was probably too much and it tore the end cap to shreds.
OK, that is an assumption on my part, but it makes you wonder what the circumstance was that lead to a failure inside the filter that lets cardboard into the engine.
OK, enough said on my part... Thanks for the input! :)
Have a good one!
Hey the OEM's pay big bucks to alot of engineers to design this stuff and sometimes thay get it right. They have to deal with gigundis law suits though so they have to be conservative in what they incorporate in the design.
Of course, as with any other component there will be failures. The problem I have with fram is personally hearing of 2 or 3 that have potentially ruined motors.
I have also heard of a K&N filter failing on a turbo Buick V6 motor. It actually violently exploded on the starting line at the drags. This was said to be due to ultra fine filtration with a high pressure oil pump. I'm not sure if the valve failed internally or what happened, but it was a big mess.
Does that mean I wouldn't use a K&N? No, just be careful what application you use anything on.
But, why would you use Fram, when there are obviously better filters out there for about the same money, if a few dollars more? Just doesn't make sense to me.
For example- AC Delco. These aren't half bad filters. They don't have the finest of filtering, but they're well made.
I think the issue with the "2 Full Turns" all depends on when you start to count the turns. Each persons grip/hand strength could cause variations in the start of the count. If you start counting as soon as the filter makes contact then it should be fine but if you turn it as far as you can by hand then you may only need to turn it 1 or 1.5 times. All depends on the person's strength.
Read the instructions, then there's no question on how many turns!
Sounds too easy...
This post has really gotten some mileage, unlike a Fram filter that would have blown up or grenaded the engine of any V or Wee on the planet.. :)
All filters that will work on a Suzuki Intruder VS800/VS1400 will work on the Strom
Purolator ML6818
Check the Wrenching & Tips section of my site for a complete list of filters available
Is there a Purolator Pure One for a Wee-Strom?
Sounds too easy...
That's right, just changed mine for the first time the other night, owner's manual says from the point where the rubber gasket first makes contact, that is your starting point for the 2 revolutions. OEM filter, by the way.
Steve.
Using Fram since that was what I found when I needed one. Hand-tightened.
So far so good. Still have one, might give something else a try after I use it up. Might go H-Flo or Puralator for $6, that's about my price range.
I've been using NAPA Gold 1359 (WIX 51359) on my various Suzukis (the Bandit, the SV1000 which I traded on the 'Strom, and nephew's 600 Katana) for years. They're good filters, and reasonably priced. The 'Strom's due for its first oil/filter change, and that's what I'll be putting on it. :D
We've also used NAPA filters on a variety of John Deere diesel equipment, mainly as a matter of convenience, since the NAPA guy's 3 miles away, and the J-D guy's 40. ;)
The only filter I've ever seen in 35 years that actually failed was a Purolator on a '71 Pinto (!!) that split lengthwise. This was one of the early 2 liter, OHC, "good" engines, not the later, problematic 2300 engine that had cam wear problems, was not abused or misused, relatively low (50K +/-) mileage, regular oil/filter changes. It was a company vehicle, so, they stuck a new Puro filter on there, filled up the oil and away she went. Never did figure out what caused the problem, it ran another 100,000 with no issues. :confused:
I put a K&N filter on the 'Strom last fall. When I went to change it last week, the nut on the end rounded off. It turns out that it's not a nut at all -- it's just the same pot metal used for the shell molded into the shape of a nut (confirmed when I crushed it then ripped it off with vise grips while I was trying to get the damn filter off). There's also no knurling on the end of the filter, so an end-cap filter wrench doesn't work. (I finally got it off with a strap wrench.)
I've used Purolator filters on other bikes with no problems. Comparatively, the K&N was pretty rusty. I've recently read other bad things about K&N (mostly that their filter element is not so good), but the crappy non-nut thing means I'm never buying another one of them regardless.
21 - 40 of 46 Posts
