I took advantage, of the buy a new 2011 DL650A, and get luggage for $199. So the luggage comes in, and I go down to pick it up. The luggage, and the side mounts are there but there's no topcase mount. I was explaining to the parts manager that I know I read that you need the topcase mount..there was still a new 2011 DL650A on the floor and I showed him..there's no place to screw in the side mounts..the rear rack is solid. He calls someone at Suzuki, and then has to call the regional parts manager. He didn't answer so he left a message. As soon as I drove off with the parts they had, the parts manager calls me and says the regional parts manager called him and said I have everything I need, and go home and see if it works. Well there's still no holes in the rear rack so I have no clue how it would work. Then I found where I read it..probably other than on this site. Suzuki's own website:
Required Hardware for Desired Application 1)TOP CASE AND SIDE CASES >> Top Case Mount and Side Case Mount required 2)SIDE CASE ONLY >> Top Case Mount and Side Case Mount required 3)TOP CASE ONLY >> Top Case Mount required Color match inserts sold seperate.
Part #: 990D0-06G00-066
$179.95
So if you took up their deal, make sure you get the topcase mount. Hopefully it's small enough and will fit in my backpack..really don't want to drive my truck through traffic another 50 miles round trip for a part that should have come with it in the first place. Oh I did tell the shop's parts manager to tell the regional guy..if he's wrong he owes me a topcase~!! hahahaha :thumbup:
$179.95
