Have an 02 DL1000 which is a joy to ride -
When I start up from cold I'm puzzled why only one exhaust (left side) smokes and the other doesn't? Is it a sympton of something - maybe an unbalanced carb?
Curious to know .... :?
Thanks - and Happy Christmas to all.
B
I don't think you are seeing smoke.... you probably are seeing moisture/steam. My bike does the same thing in cold weather start ups! :) It always goes away in about 2 minutes. You see the same exact thing happen with cars in colder weather. :wink:
Ditto; I read this in a FAQ somewhere... Completely normal on startup when cool out.
The moisture that comes out just one side has to do with the HPFM (hocus pocus [email protected]%$*!n magic) Mine does the same thing. Why just one side? - Don’t know. I think it might be related to the laws of thermos bottles. You know, hot things hot & cold things cold. I keep two cups of coffee and a popsicle in mine. :roll:
the smoke you are seeing is not smoke it is moisture or steam that goes away in a few minutes when your exhaust system heats up. take a look under your bike. there is a real bias to the left side of your exhaust system plus if your bike rests on a side stand then most of the moisture or condensation settles to the left exhaust. totaly normal, don't worry about it.
hope this helps.
kaos....
