Signal lights / 4-Way Flashers fault
1497 Views 4 Replies 3 Participants Last post by  soberjoe
I haven't been around in a while, yet here I am with a problem . . .
Whenever I use my turn signals, the emergency 4-way flashers are activated.
I changed out the turn signal relay and that did not help.
The 15 amp turn signal fuse is good.
Any thoughts from the collective?
As a side note, Big Ethel has been sold after taking me on 106,000kms of adventures.
Joe
Cloud Tire Sky Wheel Ecoregion
See less See more
Are all your lights original or have you gone to LED ??
Reactions: 1
Sure your switch is correct? One side is flashers, the other side is turm signals
Reactions: 1
Reactions: 1
All original.
The new owner solved the issue - the 4-way switch was dirty and would not fully return to the ‘off’ position, and activating the signals seemed to energize the circuit.
Cleaned the switch and all is well 👍
Reactions: 2
