You're not going to S. America on a motorcycle, do you? Buy yourself a cheap voltmeter if you do...
To jump start, connect cables to + and - on bike (Stroms don't have ground), then connect + on car, then - on car.
I believe Strom needs at least 11.4 volts to even attempt cranking. Turn on car engine, make sure you ignition is on, kill switch is on, gear in neutral or kick stand is up before pushing.that black button. Yes, squeeze the clutch too...
