Ridding my '18 650xa today in the fifth gear, tried to shift in to 6th gear, but the shifter lever was "missing"
, looked down and the lever was just dangling loose. The axle bolt worked itself out, lucky I had a pair of long needle nose pliers, since the regular open wrench doesn't fit.
Will have to buy a skinny 17mm and grind it to about 1/8" thickness, and remember to do the visual every time I go out riding.
Q: "What color Loctite should I use to keep it from falling out?"
