1 - 20 of 21 Posts
This is your chance to buy a big compressor. I got a 3hp 30gal at Harbor Freight mainly to seat the beads on tires originally. Now, several years later I have a bunch of air tools. Makes life easier.
ugh
Thanks guys, got it. Took the valve stem out and sprayed wd40 around the rim. Used that just because it was handy.
I believe you want to use soapy water, not a silicone based spray.
I won't lead this thread down the Starting Fluid/Ether method. It is tried and true though.
· Premium Member
Discussion Starter · #8 ·
Not true according to manufacturer. Dunno why there's so much misinformation about this stuff.... :confused:
WD-40 Frequently Asked Questions
Gad zuks, you believe the manufacturer?:jawdrop: According to the MSDS on the product it is close to 50% naptha. Naptha is one of only two chemicals that are considered solvents for rubber. I know there is still some actual rubber in a tire and I'm going to error on the cautious side.
I never tried this, but there are some videos on youtube of people spraying some starting fluid into the mounted tire, igniting it, and blowing the tire onto the bead. Looks like it works, but obviously not the safest way to do it..
· Premium Member
Discussion Starter · #12 ·
I do read product data sheets and application notes. You have to start somewhere. Why would they say it's okay for rubber if it isn't?
Even if it isn't, my tires only last 6 months anyway.
But speaking of naptha, does anyone out there besides me still have a bar of Fels Naptha soap? Do they even sell it anymore? What I have must be 45 years old.
Okay, I just looked. They still make it.
· Premium Member
Discussion Starter · #13 ·
I did consider this briefly.
· Premium Member
Discussion Starter · #14 ·
Had the same problem with the front Shinko. Resorted to getting the 6HP compressor working after exhausting the rest of my arsenal.
My brother in law does this in the barn on the log truck tires, pretty good at it. I saw him do one, as I had to see it with my own eyes, did not stick around for more.
He would never be able to get the tire mounted on the bead if he did not flash it with fluid.
· Premium Member
I tried the starter fluid once. It sis not work for me. It ignited but did not seat the bead. I bought a gallon of tire lubricant from NAPA. That helped along with a warm tire. In the winter I have put the tire on a heater duct. My old Seca 900 was the hardest. The Wee is much easier. Also some brands/models of tires are easier than others. Here are a few famous last works. The Anakee 2 front seated with floor type bicycle tire pump. The rear took the air compressor but was simple. I wonder how it will go in a few weeks with the next set sitting in the garage. Oh that reminds me for the Seca I had to stick 2x4s inside the tire and let then sit for a day to open the bead up. Doing this also helps. I better go do that with the new tires for the Wee. :yesnod:
One thing that I have found useful is to remove the valve core when trying to seat the bead. That allows a larger volume of air to pass more quickly. Obviously you need to reinflate after the bead seats. This is particularly useful when using a smaller volume compressor (i.e. 12 volt).
1 - 20 of 21 Posts
