1 - 20 of 22 Posts
I wondered if a Scotts Damper for a Wee would fit a V2 and since I had a mounting kit from a Wee sitting unused in my shed I thought why not have a go.
After removing the tank cover from a V2 I could see I was onto something, the bar clamps were a perfect fit but the bolts from the V2 would not work so I searched through my junk and found 4x8mx30mm socket head cap screws to take care of the handlebars and the mounting of the unit.
The front of the tank bolts to a bracket that is mounted to the frame with 3 button head bolts, I removed the 3 bolts and pulled the steel spacer out of the middle rubber grommet and then replaced the outer 2 bolts, I then cut the top off the middle rubber grommet so as to have a flat surface to work with.
I then found the frame mount from the Wee was a perfect fit but I needed a new hole drilled just a little closer the upright for things to line up, this was easy with a drill and the photos will show the position.
The Scotts mount centre pivot pin has a plastic collar fitted so you can set the depth, this is not required on the V2 so it must be removed.
The 6m bolt I removed was replaced and then the grub screws on the mount were adjusted just like you would on a Wee.SORRY THAT PHOTO WILL NOT UPLOAD :furious:
The tank cover fits back into place with no trimming or cutting required.
I made no changes to the bike so it can be put back to OME anytime.
Cheers Peter.
I used to ask similar questions until I fitted a steering damper. It's only been a life saver on soft sand, but it makes riding on dirt a lot easier generally.
Pete
I have made several comparisons of my V2 to my past F800GS saying I find it the better handling bike. And, for sure, all the dirt and sandy patches I rode last year (a lot) had me with a big smile on my face. Now, interestingly I did a tour with an old bud who bought his F8 the same time I bought mine. I never had a Scotts damper on my somewhat squirrelly F8 but he has ridden all over the north ands south Americas on his with one. And he just bought a new F8 last year installing a Scott damper on it saying it was a necessity.
Point being I am so far not seeing a need for one on the bike but would love to hear some comments.
I had a tank slapper on a Wee that resulted in the only crash I ever had on a bike that required a doctor for me and/or damage to the bike I couldn't easily fix myself. I've had a steering damper on every bike since just in case. Most of the time it really doesn't do anything but it will prevent the "O Lord" moments. I consider it cheap insurance.
I have posted this before.
My story is I applied for a new job, the best job in the world, I got the phone call on the Thursday to say I got the job, on the Friday I high sided my WR450f at about 10kph and broke my collar bone, I was very lucky they held the job for me while I recovered.
Since that accident I decided dampers were very very cheap and I would fit one to all my major rides, a damper is cheaper than any hospital bills, lost wages due to recovery times or motorcycle repair bills.
When a damper if adjusted properly you don't know it is there but you do know when it has done it's job, they do their best work on surprise elements like pot holes, tree roots and wildlife.
If you don't leave the city or your a very good clairvoyant then you probably don't need one but if you like to get out and about they are cheap insurance.
PS;
I have come to love the Scotts product, I have a GPR damper on my MT09 and it is rubbish, it works but it is very intrusive and there is not enough adjustment to get it comfortable.
Well Rolex, I cant agree that Scotts are very, very cheap (I see what your saying tho) here in Canada at four to six hundred. Ya, I know, I'm a cheap bastard.
Actually, now that I've gone looking, I am not coming up with one for my V2. Scott's site directly shows one for up to 09 Dl. Would this fit 14+?
That is one of the reasons for my post there is no Scotts kit for the V2 at this time. (if Scotts read this there soon will be.)
The one I used is from a 2009 DL650 and was a quick and easy fit.
You are right they are not cheap compared with beer but when you compare them with medical bills or motorcycle repair costs they are worth every cent.
Thanks for the great info...I'll be trying that soon.
Just curious if it slows down the steering in really tight mountain roads? Some times it seems as if a rider is sawing the bars back and forth , like on Hwy 190 in the Sierras.
I had a simple piston device on my R65LS BMW and don't recall it seeming to fight wanted input.
The VW steering shock I had on my sidecar rig was noticeable.
Rider steering is is not abrupt enough to be affected by the damper.
I always had a damper on my street bikes. I noticed however, that Scotts doesn't offer one yet for the Gen 2 V, they engineer these specifically for each bike application, I would expect that given the high dollar price. But I am interested in how well this damper is workikng for you even though it was from a different indended bike...
Discussion Starter #16
With the drilling of one hole the early 650 system is a easy fit to the V2 and it works great, I have Scotts dampers on all my major rides and the adjustments are endless so you will always find a setting to suit your needs.
Any idea if the Scotts damper will work with 1" up risers on the V2?
Discussion Starter #18
The Wee system should work with out a problem but you will need to leave the plastic collar in place to set the height of the pivot pin.
There is a small chance you may need to purchase a longer pivot pin from Scotts but I do think the standard pin will be long enough, if you do fit one please report back and tell us if a longer pin was required.
Cheers Peter
Cheers Peter
Thanks, good to know there's a solution if it's an issue. I'll probably end up doing this, but not right away. Currently working on some fueling and suspension mods on the DR so just one bike at a time.
1 - 20 of 22 Posts
