I removed Scott Oiler from KLR650 before selling bike with plan to install on Vstrom. On KLR I would run at minimum setting and this was getting plenty of lube to keep chain lubed. I would also shut off completely about 20 to 30 miles before riding any dirt and until got back onto pavement. My advice would be to set oiler at minimum and just check chain for any sign of dryness. The Scott Oiler does not use much oil to keep chain well lubed.
I have decided to not install Scott Oiler on my DL1000 because off potential problem with too much lube resulting in dirt accumulation at clutch slave cylinder and subsequent clutch push rod issues.
